No Spark on 200cc Vertical Engine
Old Aug 7, 2016 | 03:34 PM
CT22Canada's Avatar
Default No Spark on 200cc Vertical Engine
Hello everyone at ATVConnection,
This season is my first time ever owning an ATV, so I am new to the ATVing world. I am having trouble getting my 200cc chinese vertical engine to start. My problem is no spark.
I am really not sure what CDI and regulator I need, as the ATV was missing parts. I think I need a DC CDI and 4 pin regulator, but I am not sure.
My stator has the follow (5) wires coming out of it.
Two are together in a group. A blue w/ white wire, and a green w/ white wire. Three are together in a group, all are yellow.
I believe the blue w/ white wire is my trigger. I get a 0.075 VAC signal when I put my multimeter on it.
The green w/ white wire I thought was my power to CDI but I only get 0.120V AC from it. Which is way under what I need I think.
The yellow wires each give me 3.5 VAC, or a negative value on DC. They are all tied together when I check for continuity between them.
I am thinking maybe I need a DC powered CDI that works off my battery.
So do I need a DC powered CDI that takes power right from the battery?
What is this green /white wire for?
Are the 3 yellow wires AC power out that needs to go to an AC regulator?
I also found an electrical schematic that might solve my problems but I am not sure. It shows (3) yellow wires going from the stator to the regulator, which I think is AC. (2) wires going to the CDI, and it looks to be powered by DC, am I correct?
I was able to find a picture of the stator I am 90% sure I have. It has the same wires out shown. See link below.
18-Coil DC-Magneto Stator for CB250cc Water-Cooled ATV Dirt Bike K079-013 Order<$18no Track Online with $103.59/Piece on Good_co_ltd's Store | DHgate.com
Any help would be greatly appreciated. I have tried the spark test (putting the plug against the engine and starting) and have yet to see a spark.
Thank you for any help. I can provide any additional detail as well.
Old Aug 8, 2016 | 10:38 AM
Zrock's Avatar
Super Quad Patrol
Looks like you need a 5 pin cdi. Look at your cdi and hit up ebay and match up the connector style.. Same goes for voltage regulator
Old Aug 9, 2016 | 12:12 PM
CT22Canada's Avatar
Default Problem Solved
Correct, I needed a 5 pin DC CDI, which is not common. Sparks good now.
Old Aug 10, 2016 | 09:06 AM
Zrock's Avatar
Super Quad Patrol
Easy to find on ebay.. I always order 2 or more off ebay then you always have a spare kicking around.
Old Aug 10, 2016 | 12:03 PM
CT22Canada's Avatar
I got one at a local store that carries a lot of Asian parts on the wall. EBAY is great, but delivery is way tooo long. It will be snowing where i live by the time i get it.lol.
Thanks for the help
Chris
Sgtshultzy
Feb 19, 2003 07:04 PM
bplemmons
Jul 19, 2000 10:32 PM
Howard
Oct 29, 1999 10:58 PM
newbe
Oct 2, 1999 01:58 AM
