flywheel/magnito puller 2011 taotao 125D
Old Aug 13, 2016 | 10:51 AM
bubba143826's Avatar
Default flywheel/magnito puller 2011 taotao 125D
starter chain replacement dont see a way to put the new chain on without pulling the magnito off but dont know the size of the bolt 22/23 mm im guessing
took starter sprocket off
do the 3 allen screws have to come out?
Old Aug 14, 2016 | 02:58 AM
Looks like a Honda E22 clone engine, so Honda Cub flywheel pullers should fit. The allen bolts don't have to come out unless you are replacing the one way clutch. I have used the allen screw holes holes to make a three leg puller when I couldn't get the proper one, but it is risky as you are in trouble if a thread strips.
Old Aug 15, 2016 | 11:00 AM
Zrock's Avatar
Super Quad Patrol
im really not seeing why you cannot put the chain on over top? Does the chain not have a master link so you can pop it apart if needed.
Old Aug 15, 2016 | 07:53 PM
Default Starter chain
No there is no master link and there is a guide that prevents me from just slipping it on
Old Aug 19, 2016 | 02:44 PM
MPDano's Avatar
You can get a cheap 3 leg puller from Harbor Freight. They come in handy for all sorts of stuff. I had also bought one of those clutch pullers for my old Honda Odyssey and so far it's most everything I own (Chinese, Yamaha and KTM).
Old Aug 19, 2016 | 06:59 PM
Default Puller
Can't get the bolts off with an impact
Old Aug 19, 2016 | 07:32 PM
MPDano's Avatar
What bolts? The 3 allen bolts? If so, didn't someone already answer that for you?
KennyLaraba
Feb 21, 2022 11:13 AM
can-amsledder
May 15, 2020 10:54 AM
jpcjguy
Aug 18, 2016 12:31 PM
1stimer87
Aug 9, 2016 02:29 PM
Timbo2500
Jun 12, 2016 11:34 AM
