oil doesn't go to top head
Old Apr 9, 2018 | 08:37 PM
jerry fathi canada's Avatar
Thank you merryman
ok oil pumping out to radiator and coming with good pressure out of radiator and go to engine . but unfortunatelydoesn't come bake to filter so I did crank engine again today and just air ispumping out to filter hosing I put some oil by the hand in the that filter hoseand crankbut was pump out so slow so isonly air is coming out no oil at all . any id what is wrong ? if you can help is muchappreciated
thanks for all help you did
jerry
Old Apr 9, 2018 | 08:47 PM
oil not coming out of this hosing to filter only air is pumping out
Old Apr 10, 2018 | 03:38 AM
According to your previous drawing, oil comes in through the outside of filter, then out of filter centre into the cover plate, and back through that hole you have marked in red to go to the crankshaft etc, so oil should be coming up into filter housing from sump, not through that hole.
Old Apr 10, 2018 | 10:55 AM
Dear merryman
I'm really sorry if make headachefor you or if I can't explain well is language problem
yes in the picture I try to explainhow the oil pumping { going out } from engine out to radiator also coming outof radiator with good pressure and going back to engine . but from return theoil to filter I don’t see any oil coming to filter or filter hosing only air pumping out fromthat hols I mark red . so if oil should come out from different hose oranything ells I don’t know if you can show me I send you oil filter hosing tosee it
again sorry for all the problem
thanks
jerry
Attached Thumbnails oil doesn't  go to top head-oil-20filter-copy.jpg   oil doesn't  go to top head-maxresdefault-2.jpg   oil doesn't  go to top head-maxresdefault-copy.jpg
Old Apr 10, 2018 | 05:46 PM
  #15
Dear merryman
sorry again
ok I find out which holes oil is coming out . reason I find becauseI have other atv exactly same model so Idid open filter and crank motor and see the oil is coming from inside holes under filter .but now oil is pumping good in and out of radiator but from inside of enginenot going to filter . so what can be wrong
really appreciated for any help
thanks again
jerry
Old Apr 11, 2018 | 03:14 AM
  #16
Either the oil pump isn't pumping enough oil, or the pressure relief valve is stuck open. Or one of those oil pipes in the clutch housing is loose or leaking. I don't know where the pressure relief valve is, but the clutch cover will need to come off to check all of the above faults, the book should tell you.
Old Sep 2, 2020 | 04:08 PM
  #17
Spatariu Robert Paul's Avatar
Default oil does not go to the top at odes 400cc clone honda 350 rancher
oil does not go to the top at odes 400cc clone honda 350 rancher ! Please !!! help me <3
Old Sep 3, 2020 | 02:20 AM
  #18
Well if reading the 15 previous posts haven't sorted you out, I don't know what will. One point about the 350 Honda it takes ages for oil to get to rocker cover after you start engine, are you sure you are waiting long enough before panic sets in?
Eyeballsdeep
Mar 16, 2018 12:54 AM
aaustins14
16
Mar 7, 2018 11:41 AM
Chain123
Jan 19, 2018 10:35 AM
cswiger
Oct 2, 2017 04:30 PM
ScoobyDFW
May 7, 2002 03:16 PM
