No power in neutral light or ignition switch
Old Jan 13, 2019 | 09:27 PM
rstoneb92's Avatar
Default No power in neutral light or ignition switch
I have a 99 Yamaha Timberwolf 250 and I have no power in the neutral light or ignition switch. I do get power to my head lights. It has a good battery and fuse is good. What should I start with? Thanks in advance.
Old Jan 14, 2019 | 03:22 AM
Fairly sure the ignition switch also turns the lights on and off, so I think you are getting power to and from the ignition switch. Try to get hold of the wiring diagram, and trace the neutral light circuit back to the ignition switch. There is a lock-out that prevents the starter working unless the neutral light is on, which makes this circuit very complex. You would be better posting in the Yamaha section by the way.
jm91rs
Dec 31, 2018 01:16 PM
Ratsnestii
Dec 23, 2018 05:33 PM
Megamole
Dec 21, 2018 02:12 PM
Lyle1984
Technical and How-To Articles
Dec 12, 2018 08:28 AM
James Merritt
Nov 20, 2018 01:20 PM
