Tao Tao 110cc Dirt Bike No Spark
So I purchased a new 110 from Amazon for my grandson. It’s kick start automatic 4 speed. Besides tightening bolts up and changing the spark plug to a NGK the bike has been tuning great.
Here is the issue. My daughter was riding the bike and it just stop running after about 30 minutes of run time. She called me and I came over pulled the plug and seen it has no spark. I have yet to check anything so I’m asking where would be a good spot to start. Is there any certain part that seems to fail after about a month or so?
Thanks in Advance
Bill
Thanks in Advance
Bill
Try a new plug, probably not the problem, but easy and cheap to swap. Read the sticky at the top of this page on stator testing. You can't test the CDI itself, so you test the stator, and the other wires going to the CDI. If they all test out OK but there isn't an output from the CDI, the CDI must be faulty.
Yes I’m a parts replacer when it comes to electrical lol
With Chinese replacement parts you are wasting your time going down the substitution road, as you may well be fitting faulty new parts and end up with two faults instead of one. Also, if the CDI earth wire isn't grounded properly, it will blow every new CDI you fit, so you must ensure the wires to the CDI are testing out correctly before fitting a new CDI, and you need a meter for that. This should also tell you if the stator is working properly
blametruth8
1) Engine problems..
02-20-2017 04:56 PM
