Warmup
Old Aug 18, 2020 | 11:59 AM
Cakebox181818's Avatar
Default Warmup
Quick question, why does my atv take 30 min to warm up? I have to do 5 minutes of idling or driving slow, then shut it off for 10 minutes, drive it for 15 minutes and after that it gets good. If i do not do this it will barely pull its own weight. Its a 50cc.
Old Aug 19, 2020 | 01:57 AM
Seems like it is running lean, check the plug colour after it has run for that half hour, death white on the nose and surround would indicate a weak mixture, probably a partly blocked jet. Clean the jets and the passageways out with compressed air, re-assemble, and see how you go.
sdbowhunter
Feb 1, 2006 11:33 PM
skooter525
Sep 29, 2004 10:07 PM
crispy
May 14, 2003 08:01 PM
SprintPusher
Utility ATVs
18
Apr 17, 2002 01:34 AM
