Apollo Blazer 9 no longer runs after washing
Old Feb 9, 2021 | 11:41 PM
ServrH's Avatar
Question Apollo Blazer 9 no longer runs after washing
Was pressure washing the quad as usual ( ATV was not running of course ). ( But with the battery hooked up, pretty stupid of me I know)
Anyways once I was done I fired it up and drove it around for about 10-15 minutes. Let it cool down and put it in the garage for storage.
A day later and now it's not starting, pulled the plug and what do you know, no spark. Pulled the front cover for the wiring and made sure to dry everything off with an air duster to make sure there was nothing shorting. Checked the stator and the readings are perfectly fine. I pulled the killswitch wire on the CDI to see if maybe one of the killswitches was "stuck". Still, nothing, my only two options at this point to my knowledge are replacing the ignition coil and/or the CDI.
Any second opinions on this? I'm just a beginner and have come to those conclusions through a few hours of research and troubleshooting. Any advice would be greatly appreciated.
Old Feb 10, 2021 | 03:34 AM
Go through the help diagnose stator sticky at the top of this page before replacing anything. This should tell you where the fault lies. Also if, for instance, the earth to the CDI was bad, it blows the CDI, simply putting in a new CDI would result in that blowing too.
Just My Luck!!!
1) Engine problems..
13
Jan 29, 2017 02:34 AM
Saskyrider
Jul 30, 2012 10:30 PM
newfonfire
Oct 24, 2008 02:39 PM
splatman
Jun 24, 2007 02:31 PM
anthony7
Feb 26, 2004 09:23 AM
