Apollo Sniper battery issues?
Old Dec 14, 2023 | 12:27 PM
Anderson3530's Avatar
Default Apollo Sniper battery issues?
I have an Apollo Sniper 125. I got the ATV with a dead battery. We jumped it and the ATV ran fine. However the battery wouldn't hold a charge. I replaced the battery and the new battery wont initiate a crank. Additionally the new battery has now drained since being connected. I used my pickup and jumped the AT Vand was easily able to get it run. Thoughts?
Old Dec 15, 2023 | 03:31 AM
Seems like there is a constant heavy drain on the battery. Any drain which occurs with ignition off will probably be through the voltage regulator. Charge the battery up, then put a high ampage ammeter between a battery terminal and the battery, see if there is a drain, if there is, disconnect the regulator wiring plug and see if the drain disappears.
mcordani
Aug 1, 2012 04:40 PM
Off_Road_Ram_01
Apr 16, 2008 05:50 PM
700cc
Dec 12, 2004 02:01 PM
adamant
Dec 17, 2003 08:10 AM
