Battery life
This is on my 07 400 auto 4x4. I haven't ridden my quad much this winter - ran it a few times and it started fine. Now today go to fire it up and the battery is drained. It will crank a few times, but not enough to get it going. I know since I didn't ride much this past fall/winter I should have disconnected the battery - how long of a life is exptected of these normally? Also any recommendations for a atv / cycle battery charger?
I use a automatic car charger its shuts off automatically when the battery is charge. Cant see how it would know if its a 12v ATV battery or a 12v car battery.
If a 15 min ride cant get the battery up and running strong,then chances are the battery is done. I would not work to hard to bring a 2 year old $40 battery back to life.
https://atvconnection.com/F...-on-ATV-batteries.cfm
there's the article I read - towards the bottom it talks about the car charger not being the best suited for the job. I did pull start it - first pull and it fired up, but noticed my display is not working nor the winch - I assume this is due to a drained battery ? The display lights up redish orange but shows not info - I did check the leads coming off the battery to the winch solenoids and it shows 14volts, but pressing my controller button = nothing. I haven't ran it very long - maybe I will go out and start it, let it run for 15 minutes and see what happens. thanks for the replies....
Do worry about the display and winch that will work ok once the battery is charged or changed. Sitting and just idling is a slower charge than with the motor reved up durring a ride. Even after a 10 min ride it should run ok,or something is wrong.
From your link it sounds like using a car battery is not the thing to do on the more exspensive AGM batteries.
I just buy the cheap "Conventional" Walmart batteries so I guess it does not apply with me.
I ,m more surprised the ATV and sleds fire up every season with these batteries, than surprised if they do not.[img]i/expressions/face-icon-small-wink.gif[/img]
Well talked to the dealer - for the car battery charger, they advise as long as you have a 2A charging selection to use that one. The higher one can possibly overheat the battery. I have enough juice to start the quad on its own but no juice for display or winch. Putting it on the charger now and hopefully all will be well here in a few.
Guest
Posts: n/a
Hello,
The key to Motorcycle & ATV battery life is really activity. The more it get used regularly the longer it will last.
I would recommend if the ATV (or Motorcycle) is going to sit for any period to use a Battery Tender. They are automatic chargers that are intended to be left on the battery for how ever long the unit sits. That way when you go to use the unit the next time the battery is in top condition. Some of the Tenders even come with a wire lead that is meant to be left on the machine. Then when you park it you just plug the quick connect in and forget it about it until its time to ride again.
My personal favorite and the one I recommend is the Battery Tender Super Smart Battery Tender Plus. It not only charges the battery but cycles it. The cost of the Tender will pay for itself when you don't need to replace the battery.
Here is a list of all the Battery Tender we have available.
John
John
cody500ho
14
08-14-2015 05:03 PM
