2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Rear sprocket removal
Old Feb 14, 2018 | 08:33 PM
John ONeal's Avatar
Default TaoTao 250 Rear sprocket removal
I would like to do some upgrades to my recently acquired 2013 TaoTao 250. I have run into an issue removing the rear sprocket. In the tutorial videos I have watched the sprocket is mounted on the wheel side of the mounting flange allowing it to be unbolted and removed when the left rear wheel is off . Looking at mine it is mounted on the inside of the mounting flange trapping it between the flange and the axle carrier. Any help is much appreciated.
View from LR wheel
Old Feb 14, 2018 | 10:54 PM
jaikai's Avatar
Interesting. May have to remove the axle and strip from the other end? Sorta looks like it.
Old Feb 15, 2018 | 06:10 PM
John ONeal's Avatar
It appears I will have to pull the axle to make the sprocket change . Not being familiar with Chinese ATV`s I was hoping there was an easier way .
Old Feb 23, 2018 | 08:54 AM
hugemoth's Avatar
Yes, you have to pull the axle. I believe the same axle is used on several models by flipping things around, thus the design. Easy to do though.
Sceiks
Nov 30, 2003 02:28 AM
Faded
Nov 5, 2003 12:39 PM
y2kex
Jun 14, 2000 11:06 PM
y2kex
Jun 14, 2000 04:02 PM
