One dinli questions, one tao tao
Figured i'd get both my questions knocked out and save some space. The first one is about a dinli Trex 90. Runs greats, except at WOT after about 10-15 secs, then just falls on its face, and usually dies. Kick is over, starts right back up, and runs fine again, only affected at WOT, no where else. When it doesnt stall afterwards, takes about 10 seconds, and is ready to run again. Any suggestions?
Next question is about a little 2007 tao tao 110, i want to get rid of the kill pull cable in the back (safety lanyard?). Would i be correct in assuming that if i just cut and capped off both wires, that would do it, or do i need to cut both wires and wire them together. Having a hard time finding a wiring diagram for the little quad. And also finding a service manual.
thanks for all your help!
....first one is about a dinli Trex 90. Runs greats, except at WOT after about 10-15 secs, then just falls on its face, and usually dies. Kick it over, starts right back up, and runs fine again, only affected at WOT, no where else. When it doesnt stall afterwards, takes about 10 seconds, and is ready to run again. Any suggestions?
....Next question is about a little 2007 tao tao 110, i want to get rid of the kill pull cable in the back (safety lanyard?). Would i be correct in assuming that if i just cut and capped off both wires, that would do it, or do i need to cut both wires and wire them together. Having a hard time finding a wiring diagram for the little quad. And also finding a service manual.
Thanks for the tip on the tao tao, unplugged that connector tonight. And gas flows freely from the dinli. I have a shorty line on the tank vent, and doesnt seem to be obstructed at all. Is there a carb setting that can be adjusted for this? Appreciate the help.
Looks like im down now to just the dinli. I've had it with the tao tao. Burnt up its second starter today, on top of the fact that before that, i havent been able to get it to start for months! Man these little chinese quads are frustrating.
, i would've leaned towards the vacuum lock on the fuel tank that's already been discussed. hmmm....
It was the cdi. After completely stripping the dumb thing down, cleaning everything, checking every wire, of course, it was the $4.95 ebay part.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
