tao tao 110 no spark
Hey everyone,
I have three tao tao 110 atvs for my kids. last week my daughter was riding and hers quit. no spark. i changed the plug and swapped all of the electrical components over form one to the other with no avail. tried coil,cdi,kill switch,ignition switch, etc. i literally have swapped everything over and this one still will not spark. i have extensive mechanical background and it has me puzzled. the only thing left is the stator. any suggestions before i go there?
Welcome to the forum tja2841!
I moved this thread so you might get more responses..
Im not a real electrical expert (not even close to Lynns knowledge) so the first thing I do is look for a bad wire connection(this has taken 2 of my Chinese quads at different times) Id pull all the connections apart and re crimp them so they are a snug fit..
The other thing I look for is a bad ground..(this was the case with one of my quads) ALL the ground wires went to 1 place and it was a very thin wire.
If you dont have a OHM meter Id get one of those.. real handy to check if wires are good and if your getting the correct volts to the right place..
i read alot of responses for similar posts and it helped me a lot! i did get it fixed and it was the stator. i swapped it out with one of my other ones and it fired right up!! but thanks for your reply and to everyone for all of the info on here!!!
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
