110cc backfiring?
Old Jun 27, 2011 | 01:30 PM
lotus7's Avatar
Default 110cc backfiring?
Hi guys, our 4 stroke 110 a/c engine will backfire after having the throttle at mid or higher and then letting it back off? What can be causing that?
the engine ignition timing is fixed so it cant be that and I cant see how the engine timing could have changed.Could it be a too rich carb setting?
Old Jun 27, 2011 | 01:52 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
A lean condition will cause that... also could be caused by a leak where the head pipe mounts to the engine..
Old Jun 27, 2011 | 03:42 PM
dog walker's Avatar
Running too lean, most of these chinese bikes/quads come like that. You can try changing the needle clip postion, adjusting the air fuel mixture and swapping the main jet for a larger one.
Old Jul 4, 2011 | 10:59 AM
lotus7's Avatar
Yea,I thought it might be too lean as well,but the plug is really black,and you can smell how rich it is burning.I am stumped at this point.
Old Jul 4, 2011 | 12:20 PM
KTM Patrol
Former Chinese POW!
To get a good plug reading checking the jet (main jet) that would be involved in a high speed back fire..... ride the machine at full throttle.. leaving the throttle pegged.. hit the kill button....coast to a stop... then pull the plug.. if you let off the throttle at any point before killing the engine.. the reading is flawed..
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
wrencher82
Sep 28, 2015 10:02 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
