Just got a v-force!
Old May 30, 2003 | 11:23 PM
98cobra's Avatar
Default Just got a v-force!
Wow I just got a new vforce, man this thing moves! For an auto and me being 220lbs. leaning forward wheelies without issue.
You almost don't even realize the weight of the machine awsome! Only question I have is it won't stay running when I let of the gas just stalls, to start it I have to throttle it to get it back running but it doesn't happen all the time so my ? is could this just be adjusted?
thx
Old May 30, 2003 | 11:28 PM
Force's Avatar
Start it with choke on to warm up a little bit. Turn up your idle a little bit not to much or tranny will grind when you put it in gear.
Old May 30, 2003 | 11:33 PM
sportyroxx's Avatar
It will go away after you ride it for a little while and it breaks in. Welcome to the team man.
Old May 31, 2003 | 03:09 PM
predator530's Avatar
man i want one of those
Old May 31, 2003 | 04:34 PM
98cobra's Avatar
sporty and force thanks problem solved just need to be ridden hard for a while. the steering on these is awsome responsive as hell
wish it had a bigger gas tank, it sure can guzzle. It has such great throttle response without a clutch kit, does anyone know any sites to get stuff for it?
Old May 31, 2003 | 05:24 PM
sportyroxx's Avatar
I know IMS and Roll Design are making alot of stuff for the V-Force. IMS also has a bigger gas tank for it, around 4 gallons I think. Elka has a suspension set for it, and there is lots of exhaust companys making duals for the beast. I know that DMC, HMF, and Yoshi have pipes out right now, and virtually all exhaust companies are trying to get pipes out for it. I think K&N has an air filter out. Try RockyMountainAtv.com to see what you find.
doggster
Nov 22, 2001 11:32 AM
azelmo
Sep 11, 2001 09:18 PM
azelmo
Jul 13, 2001 03:50 PM
adamnieman
Apr 22, 2001 07:31 PM
ctbanshee
Dec 2, 2000 11:10 PM
