Pull starting an auto?
Old Jun 11, 2003 | 06:48 PM
bbertram's Avatar
Default Pull starting an auto?
Is it possible to pull start an auto? I don't mean recoil I mean pulling it with another ATV.
Old Jun 11, 2003 | 09:00 PM
bfb750BF's Avatar
Good question -
You should be asking this question on the Polaris Forum, as both the 600 & 700 don't have a back up recoil starter.
If your battery is that DEAD & won't start even with the recoil back-up, then you may be eating allot of dirt on the way home, as most tow straps are not very long.
Whenever any of our batteries have given out, it is always out in the boonies but in all those cases, the back-up recoil did the job.
Old Jun 11, 2003 | 09:31 PM
bbertram's Avatar
If the battery is dead how can the fuel pump work? I guess you would hope there is enough fuel in the carbs still and then the alternater would provide power to the fuel pump?
Old Jun 11, 2003 | 09:41 PM
Oxygen's Avatar
I would guess it won't start, the centrifical clutch doesn't engage until the engine
is turning somewhere around 1100-1200 rpm, you wouldn't have any connection
between the engine and wheels. But I could be wrong, somebody probably has
tried it.
Old Jun 11, 2003 | 09:55 PM
SHOTGUN's Avatar
Nope [img]i/expressions/face-icon-small-frown.gif[/img]
Old Jun 12, 2003 | 01:22 AM
400PrarieXLT's Avatar
yeah, my 400 wont pull start, I wasnt trying really, but got pulled once and left it in gear. just made bad noises.
Old Jun 12, 2003 | 01:46 AM
bfb750BF's Avatar
What spare TOOLS do you carry?
Auto or not, I always have my 15 ft tow strap in with of my other tool kit, portable air-pump, rain gear, duct tape, bailing wire & so on.
If you ride alone, best always have the cell-ph too!
Old Jun 12, 2003 | 10:30 AM
sxr6's Avatar
If it's a constant belt engaged auto like Yam or Suz, yea it should pull start, but you won't be able to pull a Pol or Bomb auto because the primary ( with is attached to the crank ) has to be spinning to engage the belt.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
mikerublee
Jun 25, 2015 09:31 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
