more ground clearance for a prairie
Old Jun 13, 2003 | 12:42 PM
prairieridr650's Avatar
Default more ground clearance for a prairie
does anybody no of any ways to increase the ground clearance on a 2003 Prairie without buying a lift kit or new tires?
thanx
2003 Prairie bone stock
Old Jun 13, 2003 | 01:11 PM
MDG's Avatar
MDG
You can get a little in the front by moving the struts up in the knuckle. Gets you about an inch. This is how the Quad Boss lift kit raises the front. I bought it and saw that it was a little bracket in the back and instructions to move the strut up in the front. I sent it back. I wouldn't feel comfortable doing that to the strut although there are people on here that have done it. It just seemed like a rip off to pay a company to tell me to do that.
Old Jun 17, 2003 | 02:07 PM
PRAIRIETWIN's Avatar
Put 35 lbs of air in all four tires and hang on!!!!!!!!
Old Jun 17, 2003 | 08:40 PM
mudhound's Avatar
I if your don't mind a stiffer ride in the front get a set of progressive springs for the front gives you 1-2" lift dependng on how high you crank the ajustment ring. On the back I cut the lower part of the shock off by the mounting eye and welded a 1 1/2" spacer in where I cut the shock and welded the eye back on.
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
