how much towing power is on the HONDA RECON
Old Jan 26, 2000 | 07:35 PM
lovinhonda's Avatar
if any of you have a recon that has a hitch
how much can it pull
Old Jan 26, 2000 | 07:47 PM
clindst's Avatar
im not to sure about this, adn honda does not post and specs on towing for the rcon, but i would guess it can haul a hefty amoust, i ahve a trx 300 4by4 and i pulled a 6000lbs boat that had its tires in little dips because of it weight sitting on dirt, Im not saying that i jsut put it in 1st gear and it pulled the boat wiht no trouble, but i did the rocking technique , where you pin the throttle until the boat gets jerked a little and let it roll back the on its forward rock pin the htrottle again adn ull eventually get it out.
that is the nice thing about manual shift atvs you wont strees any belt, so you can pull a lot, but you can pull all you want wiht a belt driven atv as long as you make sure oyu ahve enough tension or "pinch" on the belt
Chris
Old Jan 26, 2000 | 08:32 PM
FOREMANes's Avatar
I'm not sure the wieght but I have seen a recon tow a 6x10 trailer with hay stacked up 8ft on it around, man it shocked me to see it, they had to have a guy ride on the front rack to keep it from standing on end when they were moving!
Brad <a href="http://briefcase.yahoo.com/bcj001">MyFOREMANes</a>
99'FOREMANes, 26" BUGS, Maier full chasis skid plate, A.P. bash plate and stick guards, winch, supertrapp ids, K&N, dual snorkel, and a jet kit, yea buddy..
Old Jan 26, 2000 | 10:10 PM
Reconrider's Avatar
I was pullin a boat out of my grandmas pond. It weighed around 100 pounds but wasnt hooked to a trailer so there was friction against the ground. it also had some water in it from the rain. It was hard keepin the front end on the ground though, pin the throttle, let off , front end hits the ground, repeat process.
Old Jan 29, 2000 | 02:25 PM
HondaHunter's Avatar
Never had a problem pulling with the Recon. I've towed trailers of dirt, gravel and even a trailer with kids for a hay ride. depending on the weight you may want to lay over the handle bars, but it's really a stout bike.
Old Feb 26, 2000 | 10:46 AM
Wheelie_man_00's Avatar
My 1997 honda recon towes boats from the front of my house to the back all the time. I had my honda recon toing about 1200 pounds at one time but that is not tongue wait and it was on grass in my back yard it towed it no problem the front end did start to rise however but twhn that happends lean to the front and u will be all right.
HONDA RECON FOREVER
Old Mar 1, 2000 | 11:24 PM
JJdynomite's Avatar
I have towed a 1200 bushel grain buggy , that was when it was empty but was goingn up a hill and the front end never came off the ground
97 Honda Recon
Nondem
Feb 22, 2020 12:20 PM
greg74
Sep 10, 2019 03:03 PM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Scottma518
Jul 10, 2015 12:42 AM
MNatv89
Jul 7, 2015 11:36 AM
