Sportsman 600 Rear Suspension Failure
Old Jun 24, 2003 | 11:14 AM
ResQMe140's Avatar
Default Sportsman 600 Rear Suspension Failure
The welds on my rear suspension of my new Sportsman 600 never penetrated. This was true on both sides, causing my rear suspension arm to break off. The weld was on the top but NOT all the way around either.
When Polaris was contacted, they said they knew that bikes went out that way but that the engineers told them it was OK.
I now have a bike with 500 miles on it with a broken rear suspension. I urge you to check out the welds on your bikes.
Old Jun 24, 2003 | 11:37 AM
MarkV's Avatar
Which arm, upper or lower? Which joint, inner or outer?
I would assume this problem would spill over into the SP700 lineup as well since they use the same parts.
-Mark
Old Jun 25, 2003 | 12:02 AM
ResQMe140's Avatar
Both joints of the inner -- they were both welded only on the top and bottom and not all the way around. No heat with the weld, therefore, no penetration!
It was ugly,
Therese
Old Jun 26, 2003 | 11:03 AM
MarkV's Avatar
Did Polaris make good on it? Were you riding when they broke? That must have been rough, if so!
Old Jun 26, 2003 | 11:41 AM
lovemud's Avatar
What was the date of manufacture ? (located by the serial#) that would help narrow it down for the rest of us.
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
Jkfx400P
Jul 6, 2015 10:04 AM
