nitrous
Old Jul 3, 2003 | 05:51 PM
steamboat's Avatar
Default nitrous
I can pick up a nitrous kit for a couple hundred bucks. Comes with a small bottle - 10 lb I think - Could I put it on my stock 400ex. I would make it a dry set up. It would squirt in to my air box between the air filter and carb. Would this be fun to ride or not?
Old Jul 3, 2003 | 06:04 PM
trx250Rob's Avatar
Default nitrous
It would work ok as long as you are not going for huge hp with a dry system. 10 hp would be safe and I would have it fire between the carb and airfilter.
A 10 lb bottle is a bit big.
Old Jul 3, 2003 | 06:16 PM
HA2's Avatar
HA2
Default nitrous
i think most guys run a 2lbs bottle and mounting it to the cooler rack makes for easy install/take off.
Old Jul 3, 2003 | 06:44 PM
whatwasthat's Avatar
Default nitrous
you will run VERY lean with this setup.. you will have to jet the bike richer to run right..
i was considering running nitro on my 400, but i decided not to (more to riding than dragging to me) but i wsa going to do it defferently. i was going to run a wet system, i was going to have a fuel pump off a seperate fuel line setup so that when i hit the rpm where i wanted the hit, it would activate the pump so i wouldnt run lean with nitro or be too rich when not running the nitro
Majorecho
Dec 19, 2006 12:51 AM
saint650
Aug 6, 2003 10:18 AM
iluv2fly
Jul 28, 2003 01:55 AM
WIDELOAD
16
May 10, 2003 12:36 PM
OrganDonor
Feb 22, 2002 02:29 AM
