reverse problem.......
Old Jul 26, 2003 | 07:17 PM
Justin327's Avatar
Default reverse problem.......
Hey ppl, I have a 2001 Magnum 500 4X4. when in a tight spot in reverse, at idle, i turn the handlebars all the way to the left or right, and the bike stalls. Any suggestions? Thanx in advance.
Old Jul 26, 2003 | 07:24 PM
hotseatperformancefan's Avatar
are you holding the overdrive switch in??
Old Jul 26, 2003 | 07:36 PM
Justin327's Avatar
yes i am, thanx for your interest.
Old Jul 26, 2003 | 07:41 PM
lol
Old Jul 26, 2003 | 07:48 PM
Justin327's Avatar
why laughing????
Old Jul 26, 2003 | 07:50 PM
tell you the truth i dont really know. and i cant imagine what would be wrong with it. honestly i cant see what turning your wheel would do.
Old Jul 27, 2003 | 01:32 AM
TahoeRider's Avatar
Your throttle cable may be moving when you turn the wheel.
Old Jul 27, 2003 | 01:40 AM
Traildog's Avatar
The truth is, it could be one of many problems, most likely to a wiring problem in the steering column. I would start by taking off the front cover and very carefully with the engine running start moving the wires around in the steering column. If you can reproduce the engine stalling pay close attention to which wire you moved. If this is an older unit it will have a large flat terminal block located under the front cover which can be a source of trouble.
Keep us posted and we will try to help.
Old Jul 28, 2003 | 09:42 AM
NCScrambler's Avatar
Your throttle cable is out of adjustment. Take the cover off of the throttle assy to expose the ETC. Now, adjust the throttle until the contacts are held together with the tension of the throttle cable. After doing that, crank the engine and with the machine in neutral, turn the handlebars lock to lock and there should be no change in the idle, if there is, then you have too much tension on the cable or the cable is routed incorrectly.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
