Warrior Carb Help!! also K&n question.
Old Aug 2, 2003 | 10:07 PM
2000IAWarrior's Avatar
Default Warrior Carb Help!! also K&n question.
how do you warrior guys recomend removing the carb to rejet it. i orderd and Alba Pipe Kit for my warrior and it will be here wed,thursday,or friday and i want it on by saterday. so i need to know how to get my carb off/ if there is any hits on re jeting it. that would be great!!ne help would be.
Also the kit comes with a kn filter do i need to buy filter oil to oil the filter b4 i use it or not?
Old Aug 3, 2003 | 12:29 AM
RaceWarrior350's Avatar
The K&N should come pre oiled out of the package so no you prolly wont have to........ I jetted mine and this is the easiest way i found to do it.......
1. Take the Reverse shift lever loose from the frame so u can lay it down on the motor sideways.
2. Losen and remove the carb from the boot with a 12mm wrench (I Think). Make sure you hold the carb with one hand so you dont crack the boot... while losening the bolts......
3.now here comes the what if part, Work the carb out tward the stator side with the cables still attached.
4. Flip the carb upside down if you can, Have someone hold the carb and try to take the float bowl screws out(BE CAREFUL THEY STRIP VERY EASILY!!!), (now heres the thing, Mine didnt come out, i had to remove the carb entirely and get it on a work bench to get them out) If they come out remove the jet, put in the new one and reassemble.
5.If they strip out take the carb lose from all the cables and use vice grips or some good pliers to take them out.......
6. Next is figuring out the jetting which im not the best at sombody else can prolly help...
Hope this helps,
Ryan
Old Aug 3, 2003 | 12:35 AM
how do u remove the throttle cable from tghe carb..
Old Aug 3, 2003 | 12:42 PM
03waryer's Avatar
Don't remove the throttle cable if you don't have to. RaceWarrior350 is right the screw head strips way easy. Bust the screws loose with vice grips before using a screw driver. Once the float bowl is off the jets are simple to change.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
