is my clutch going
Old Aug 4, 2003 | 08:32 PM
kybabyn's Avatar
Default is my clutch going
k i have a 93 mojave that has had other valve problems ect and now i think my clutch is going. when i shif into first gear at a stand still it jumps forward about an inch and makes a choonk sound. there was about an inch play on the clutch lever and i had to adjust it lots. sometimes when shifting it goes into nuetral or you hear a bad sand that sounds like a penny going round and round untill you get it into gear again. its like a loud ticking. and today i had an etcperience where my whole clutch didnt clutch. so i adjusted it like it wouldnt engage into the gears. is my clutch going or what. what are some sines of a bad clutch.
Old Aug 4, 2003 | 10:07 PM
kybabyn's Avatar
oh thanks you guys have been really helpfull! not come on anybody?
Old Aug 4, 2003 | 11:11 PM
mahnster's Avatar
just be patient, you might have to wait a few days for the answer but its worth it.
Old Aug 5, 2003 | 03:45 PM
kybabyn's Avatar
my patience with this site is running out. nobody answeres my questions.
Old Aug 5, 2003 | 06:13 PM
SpinCycle's Avatar
It sounds like you have some warpage in the clutch plates or steels. After overheating a clutch a few times you could have warped a plate and now it will not totally disengage (the creep you feel when popping into gear). Do you hear the sounds while coasting with the clutch in? could be something in the gearbox but replace the clutch first. Change your oil to, if the clutch has been used hard then the material that burns off goes into your engine oil.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
