Cutting carb spring and drilling 1/8th holes???
Old Aug 11, 2003 | 05:05 PM
JMAC650's Avatar
Default Cutting carb spring and drilling 1/8th holes???
I cut 4 coils off the carb spring but i'm not sure what hole you are supposed to drill out to 1/8th? Anyone know?
Old Aug 12, 2003 | 02:02 AM
Oldmanracing's Avatar
In the plastic vacuum slide behind the jet needle(motor side) are two vacuum ports.
Drill these two vacuum ports to 1/8 inch.
Increase pilot jet from 45 to # 50
3 turns out idle mixture adjustment screw
Old Aug 12, 2003 | 03:01 AM
JMAC650's Avatar
Thanks for the info[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 12, 2003 | 07:58 AM
PureIntimidation's Avatar
change out pilot jet?? Hmmm I never changed mine out. Would it change anything if I changed mine? mine seems to be spot on?
Old Aug 12, 2003 | 11:24 AM
When you change to a aftermarket exhaust, the bottom end will be alittle lean.
If you also add a performance cdi or advance your timing this will make it even more important to change the pilot jet to #50.
Old Aug 26, 2003 | 03:41 PM
Johnnyairtime's Avatar
From 45??
Mines a 40!
Now what...
I just bought a 45 and a 50....
Hmmmm... eeny meeny miney moe....
Old Aug 26, 2003 | 10:56 PM
If you have an improved exhaust and/or modded timing go 50
I also think that if the temps and humidity are lower in the fall/winter - 50 would be best
Start at only 1 turn out(no closer) and turn out in half turn increments.
Old Aug 26, 2003 | 11:00 PM
racerx5x5's Avatar
I have the 40, I should go to the 45.
Old Aug 26, 2003 | 11:45 PM
When you do a high rev downshift, do you experience any popping/erratic sounds from your exhaust pipe?
If you are at least 3 turns out and hear the sounds. Go to 50
The carb is not very sensitive to pilot jet changes. Going up from 40 to 50 does not affect fuel
delivery as much as flat slides.
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
Coryco
Jul 6, 2015 07:30 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
