Got my sp600 belt wet?
Old Aug 25, 2003 | 08:11 AM
bigblock454's Avatar
Default Got my sp600 belt wet?
I got my belt wet driving through a small pond. I was hoping if I let it sit for a day or two the water would drain out, no luck. How do I drain this?
Old Aug 25, 2003 | 10:02 AM
Lightman02's Avatar
what i do when that happens is i put the bike into nuetral, and rev the the engine so the belt spins and drys itself off, it always works for me even when i am in the trails. give it a shot it should work, it just might take a couple minutes of reving and spinning.
Old Aug 25, 2003 | 11:02 AM
95sport400's Avatar
Don't the new SPs have a drain plug in the bottom of the clutch cover also?
Old Aug 25, 2003 | 11:18 AM
I tried that with no sucess!
Old Aug 25, 2003 | 12:30 PM
Lockemn's Avatar
What we always do i have the nessacary tools ready to take off the cover on the trail and dry the belts. It always works for us
Old Aug 25, 2003 | 07:11 PM
lovemud's Avatar
unless you took it swimming, it shouldn't of gotten wet at all, the snorkel is above the level of the seat..... I think you should take it back to the dealer (assuming it's still under warranty) and tell them the seal around the cover is leaking. Otherwise you may need to check where the snorkel attaches to the cover and make sure it's tight and replace the seal.
or, ...... next time bring swim fin's and a rubber duck...[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 25, 2003 | 09:47 PM
upnort's Avatar
I do as lightman does. This will blow the water out, then drive slow and easy for a bit also. The clutch has an inlet and outlet for cooling. I have had mine up to the seat in water but as long as I stay moving I am ok, but if I get hung up and sit in the water then belt will get wet.
Old Aug 25, 2003 | 11:56 PM
Lamar's Avatar
What you gotta do is a little red plastic scrw on the belt case, take it out and lift up the front of the quad, and let it drain out.
Old Aug 26, 2003 | 08:13 AM
thanks, i pulled the red plug and drained out about a gallon of water. I don't think the cover is leaking, i drove into 3 foot water at 20 mph that is probably what did it. It seems to running fine now.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
