oil filter for kfx 700
Old Aug 26, 2003 | 10:42 PM
dodge20man's Avatar
Default oil filter for kfx 700
Does the 2004 kfx 700 use a fram 6017A???
Old Aug 26, 2003 | 11:50 PM
Tarrat103's Avatar
The oil filter part# cross over is as follows
Fram P# PH6017A ( kawy replacement)
Fram P# 7371 (auto conversion)
Purolator P# PL14620 (auto conversion) *Recommended*
Note: The Purolator filter is significantly larger than both the stock Kawy filter and any other auto type oil filter that I have found. The extra length of the filter will allow you to add about 4-6 ounces of X-tra oil....a good thing....highly recommend using it.
The auto conversion info is as follows: The V-Force uses the same oil filter for / as the......
1994 Mazda MX3 V-6 engine
Using this conversion you can use any brand oil filter, and you can also pick them up at any Wal-Mart or Auto Zone type outlets.
.....tarrat
Old Aug 27, 2003 | 12:15 AM
HighLifterV700's Avatar
I use the mobil 1 oil filter on mine, I noticed it was slightly bigger than stock..
Old Aug 27, 2003 | 08:16 AM
dodge20man's Avatar
Thank you for the information tarrat and highlifterv700
Old Aug 27, 2003 | 02:47 PM
MikeyBoyesq's Avatar
Does anyone know if the V-force uses the same oil filter as the P650?
Old Aug 27, 2003 | 03:04 PM
kawarider's Avatar
Yes same one I have been using fram ph6607 on both of mine,works good.
Old Aug 27, 2003 | 03:55 PM
trx450's Avatar
I use the Purolator PURE ONE oil filter, and Castrol Syntec(10-40 or 20-50, depends on the temp.)
Old Jun 30, 2021 | 04:22 PM
Mharden86's Avatar
For the KFX 700 does anyone know about the fram 4967
cherokee99
Apr 8, 2009 09:33 PM
500rubicon
Aug 15, 2005 05:23 PM
Exrider22
Feb 7, 2005 08:35 PM
Scottyjay
Apr 18, 2004 02:55 PM
RocketJoe
May 30, 2003 05:49 PM
