Clutch advise - AC 300
Old Oct 9, 2003 | 04:31 PM
nicksaab's Avatar
Default Clutch advise - AC 300
Hi, wonder if anyone can give me some advice.
on my 1999 AC 300 the clutch sounded like it was slipping a bit so I dug out the service manual and tightened the screw up and backed it off 1/8 turn.
Trouble is this doesn't let the rocker pedal engage. So I slackened it off a bit more and can engage first gear but it shrugs forward slightly and then no drive. If I rest my foot on the pedal as if to take it back into neutral I get more drive. however I can't find a bit point where the wheels will turn and the gear selector pedal will put into gear and out of gear.
I changed the oil today in case that was the problem but it hasn't made a lot of difference. I also tried to adjust the cable at the pedal end, but again can;t find a good balance.
Reckon its just worth putting a new clutch in, or should I just persavere with the adjustments. On the clutch adjustment screw, is it an extreme fine tune? Is there going to be a very small margin on the screw, like 1/16 of a turn that will allow the clutch to work, or should it start to bite anywhere?
Lots of questions I know, but not many Arctic Cat dealers in Britain, and no-one in my area who actually knows anything about them. Also would like to save the £500 ($750) a clutch replacement has been quoted at.
Many thanks
Nick.
1999 Arctic Cat 300 (4200 miles)
2000 Arctic Cat 500 (3100 miles)
Old Oct 9, 2003 | 04:44 PM
Cancat's Avatar
I have a 2000 250 Cat (Same as a 300) and have had trouble with shifting in the past. Recently I adjusted my clutch as it was slipping into second real bad, but had no trouble at all, in fact I found it to be quite forgiving. I did however experience troubles like what you are describing before, and what it eventually ended up being was a stretched shifter linkage cable. I would seriously consider checking that out if I were you. If you do find that the cable needs to be replaced her is a huge tip for you: In 2003 Cat switched to a direct shifter linkage (No Cable). You can easily switch to this type of linkage on your 99, and spend less money than the new cable is worth as well. I am from Canada and the cable linkage is a terrible design as it is prone to freezeups. Switching to a solid linkage was the best mod I have done, no more guess work, freezups, adjustments or stretched cables.
Hope this helps.
CF
Old Oct 9, 2003 | 04:55 PM
tricat's Avatar
Hey nicksaab, I totally agree with cancat. Set your clutch like the book says and get rid of that shifter cable!! A friend of mine had a 99 300 and we adjusted on the cable almost every hour until we placed the linkage off my 03 250 and it worked great!!
Old Oct 20, 2003 | 06:56 PM
nicksaab's Avatar
Thanks for the advice guys. As Arctic Cat stopped importing into the UK in 2001 I think, my dealer is trying to source me a direct linkage from the US. If he can;t get one, I'll put a new cable on and let you know how I get on. Apologies for the delay in thanking, time just runs away!
Old Oct 21, 2003 | 02:16 AM
luvthemud's Avatar
hey nicksaab, if your delaer can't get one let me know i could order you the part from alphasports or something and ship it to you! just a thought
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
