Timing for my Warrior
Old Oct 17, 2003 | 11:57 AM
sotermantoo's Avatar
Default Timing for my Warrior
I am putting my Warrior back together after replacing the cam,valves,springs, and piston. I bought the cam from Alba and when I put my lower end on TDC no matter what I do my TDC mark on my head is off. It is off just a little and if I move my cam sproket one tooth over the sprocket mark goes to the exact same place on the other side of the head mark. I am at a lost and I have taken apart my lower end and my cam chain is on the lower sprocket perfect. So, does anybody have any experience on this?
Old Oct 17, 2003 | 10:45 PM
95Wolverine's Avatar
Are you trying to align it when you have the "T" lined up in the flywheel window.. or the "F". The T stands for "Top Dead Center" and is the one you want to use. The "F" is for use with a timing light and will actually be seen just a tad before TDC. If using the "F" for timing your cam, the cam mark will fall just a little to the left of the mark on the head.
Hope this helps.
Ride on.
Old Oct 17, 2003 | 10:46 PM
Correction to the above, the cam mark will show just right of the head mark.
Sorry. lol.
Ride on.
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Reactant
Jul 16, 2015 10:29 PM
