new starter
Old Oct 18, 2003 | 10:32 PM
ftwflh's Avatar
Default new starter
Has anyone tried one of the cheap off brand new starters off of Ebay?
Old Oct 19, 2003 | 05:00 PM
vig's Avatar
vig
Default new starter
I got one of those starter gears for my scrambler, its been in for over a year. No problems so far. I rebuilt my starter with one of those kits on ebay, cheaper than a new one.
Old Oct 19, 2003 | 06:10 PM
ftwflh's Avatar
Default new starter
THanks.Anymore input?
Old Nov 1, 2003 | 12:57 AM
Polaris500HO4x4's Avatar
Default new starter
hey the cheapest way to go is to get your starter rebuilt
everything that is good stays everythiong bad gets replaced and it will only cost 50 to 150
Old Nov 1, 2003 | 09:24 AM
ftwflh's Avatar
Default new starter
I know about rebuilding starters!Mine is apart right now but inneed of the houseing that the armature goes in it has some bad gouges. I would be intersest in an old starter whit a bad armature if the housing is good.
Old Nov 1, 2003 | 10:53 PM
Rancidgumbo's Avatar
Default new starter
In my experience, Polaris makes very crappy starters. Everyone that I know personally that owns a Polaris (including myself) has had a problem with them. The solenoid in my TB is screwed up, and I don't have the knowlege or the resources to replace it, so now I just use the pull start on it.
Old Nov 3, 2003 | 07:30 AM
quadwrench's Avatar
Default new starter
I have put several of the aftermarket starters on the 2 stroke polaris' and have had no complaints on them. The only thing "crappy" I can find with the polaris starters vs other makes of quads is on the 2 strokes where the starter is mounted at the bottom of the crankcase - they tend to sit in water which eats up the splines on the armature shaft.
If there is no problem with the splines on the armature shaft, and the armature windings are OK, the best thing to do is "rebuild" the starter with a brush and bearing kit. Just replacing the brushes is only a temporary fix. You can get the starter rebuilt at www.stockers.com, including rewinding the armature, as long as the armature splines are good.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
