200s clutch problems...help?!
Old Nov 6, 2003 | 02:09 AM
dmaster79's Avatar
Default 200s clutch problems...help?!
Here's the story...recently put a new jug, rings, and pretty much re-did the whole top end. While I was at it I put a better used clutch in if that makes sense. On this '84 200s it has a centrifical clutch which is supposed to disengage when idle and engage around 2200rpm. Well the problem is it is engaged all the time. When I stop or slow down to an ideal the bike dies cause the clutch is still engaged. Is there an adjustment for this, or what did I do wrong? Any help is greatly apprecitated. It makes it hard to ride with an automatic clutch when its not automatic.....thanks guys
Old Nov 10, 2003 | 09:23 PM
pinkelephant's Avatar
i know on the big reds there is an adjustment thigy on the engine. i cant remeber which sdie it is on but its basically a bolt with a nut screwed on it. nothing too complicated. im not sure if a 110 has the same deal or how youd go about adjusting that per say but i think if you fiddled with it you should be able to figure something out.
hope this helps
lonerider856
Oct 13, 2023 03:45 PM
dannytas
Sep 26, 2017 06:31 PM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
