clutch adjustment.... help?¿?¿?¿?
Old Nov 7, 2003 | 02:29 PM
Warrior01YZ89's Avatar
Default clutch adjustment.... help?¿?¿?¿?
my clutch was slipping in 5th and 6th gear on my banshee... so i adjusted it on the lever and it didn't seem to help. now the lever has to be the whole way out for the clutch to grab.... right now, the case is off. all of the plates look good. the steel ones aren't burnt, and the fiber ones seem to be fine. is there a test to see if it's adjusted correctly before i put it all back together?
thanks!
Old Nov 7, 2003 | 02:59 PM
also, to adjust it for more grab, it should be turned clockwise correct?
Old Nov 7, 2003 | 03:52 PM
sAyIt_fmf's Avatar
Are the arrows on the cable end and engine case lined up?...if your using a stock cable...you need to line these up while making the adjustment.
Old Nov 7, 2003 | 04:06 PM
Flynbryan's Avatar
cranking on your adjuster at the lever does nothing for the quality of the engagement of your clutch. It is only a means to get ride of the free play at the lever. If you've had it over adjusted(ie: no slack at all at the lever) then your plates are probably toast. Meaning the fibers are probably glazed over. Sometimes you can fix this by turning them on some fine grit wet/dry sand paper, but if that doesn't work its time for a new set of plates. For the free play adjustment I run a nickel's thickness between the lever and the perch.
Old Nov 7, 2003 | 06:08 PM
alright... i put it all back together and i must have went the wrong way.... it slips horribly when i first take out....... i suppose i should have went counter clockwise............. i guess i'll try tomorrow again..... now i have to spend more money in stupid oil....... thanks anyways........
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
