Sportsman 500 HO vs. Sportsman 600 vs. Sportsman 700
Old Nov 18, 2003 | 10:59 PM
InsaneApe's Avatar
Default Sportsman 500 HO vs. Sportsman 600 vs. Sportsman 700
Can anyone give me any info on how these perform for trails/work (besides displacement differences)? Which is the better mudder?
Old Nov 19, 2003 | 09:36 AM
sp600towtruck's Avatar
They all are pretty much identical. Other than the engine, slight trans gearing, and weight (only 20-30 or so lbs between 500 and 600/700. You can't go wrong with either of the three. IMO, 600 has more low end than 500, and 700 has more top end than 600. I like my 600 though, you won't be able to tell much difference between the twins, but they both are stronger than the 500. I would say go ride all three, starting with the 500 and work up. Good luck.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 19, 2003 | 01:06 PM
InsaneApe's Avatar
Hey thanks for the info, Does the 600/700 sit higher (seat height) than the 500?
Old Nov 19, 2003 | 01:25 PM
4464's Avatar
That information can be found on polaris's website under specifications. @ www.polarisindustries.com
Old Nov 20, 2003 | 12:33 AM
snosnake's Avatar
same height on all three
Old Nov 21, 2003 | 12:40 AM
mooch's Avatar
If you have the dough, then the 700 is the king.
Old Nov 21, 2003 | 09:49 AM
InsaneApe's Avatar
Thanx for the info everyone.
Old Nov 21, 2003 | 10:29 AM
Or, for the price of the 700, you can get a 600 (with virtually the same performance) and a snow plow and/or winch and/or brush guard.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 24, 2003 | 11:47 PM
GreatWhiteHunter's Avatar
The 500 has (had?) softer front springs. I'm not sure about the '04 but everyone I ride with that has a 400 or 500 Sportsman has had the 700's springs installed in their fron ends. The result is a better handling quad (stiffer springs = less roll) and a bit mroe groung clearance in the front end.
Just my observations in the field...
Old Nov 25, 2003 | 12:18 PM
ttaylor's Avatar
If you need serious torque then the 600/700 is the way to go. If you are just trail riding then the 500 will get you anywhere you ever would dare to go. The nice thing about the 500 is the fact that it will consume less fuel and cost less. I for one don't see a need for anything bigger than the 500. You can add some nice accessories to the 500 for the price of the stock 600.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
