P700 Water in front Dif ?
Old Nov 20, 2003 | 10:28 PM
02Sleeper's Avatar
Default P700 Water in front Dif ?
I did my 10 hr service tonight and the front dif oil looked milky, so I am assuming I ended up with water in dif.
I rode through water this weekend but nothing deeper than 4 or 5" over floorboards. I relly dont think that is to deep is it?
Any suggestions as to things i can look for as to where the water is making its way in?
I hope it is somthing simple. I am going to ride this weekend and then check it again to make sure it is not a fluke.
Is the vent tube set low?
Thanks for any replies
Peace
Old Nov 20, 2003 | 10:38 PM
Kawi650's Avatar
First is you will get more water in when your bike is new because your front diff is hotter and the water cools it quicker and the vent tub can suck in water. Also look at your threads and make sure they are tight. Look around your axle for leaks. Also it doesn't take much water to make it go milky.
Old Nov 20, 2003 | 11:12 PM
02Sleeper's Avatar
Thanks for the reply.
I checked around the axles for any signs of leaks and found none. I need to look at the vent tube again. i am assuming it is vented pretty high?
David
Old Nov 21, 2003 | 08:49 AM
trx450's Avatar
Are you sure that the lube isn't a little gold colored, as opposed to milky? The clutches make a gold metal-flake color in the oil. It is normal.
Old Nov 21, 2003 | 11:55 AM
newbeatle's Avatar
TRX 450 is right about the color of the lube...
the vent tubes all run to the handlebar stem, & are just under the top of the plastic there... as far as water getting in, there is a chance, that if you didn't suck some in the vent, that it could have come in around the 2 X 4 / 4 X 4 engagement actuator... this is the biggest gasketed hole in the front end
Bratman2
Aug 6, 2022 01:42 AM
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tporath
Jul 11, 2015 12:31 PM
