300ex wont start
Old Dec 15, 2003 | 06:23 PM
RPJ's Avatar
RPJ
Default 300ex wont start
i jsut got a 300ex 97 from a freind and rode it hard in the mud for about 4hrs. When i was about to load it in the truck i turned her off then tryed to start it back up the same way i always do. This time it wouldn't start. The lights come on but nothin happens when i hit the start button. I thoiught maybe it was just wet wires so i left it for 3 days before i looked for problems.....she still won't start and i was jsut wondering if anyone had any good suggestions or if anyone has had this problem. Thanx
Old Dec 15, 2003 | 06:34 PM
hutchies's Avatar
May sound stupid but check the kill switch. you may have shorted out a wire but i doubt it
Old Dec 15, 2003 | 06:35 PM
400EXJumper's Avatar
This might sound stupid, but have you checked the kill switch? I have a 400ex and on my second or third ride I must have switched it to off with out knowing. Headlights were on, everything was normal and it just sat there cranking away. It only took me about 20 min. to figure it out.
[img]i/expressions/face-icon-small-blush.gif[/img]
Good luck!
James
Old Dec 15, 2003 | 06:36 PM
Looks like I was a little slow!
Old Dec 15, 2003 | 06:40 PM
hutchies's Avatar
Jinks you owe me a coke!
Sorry couldn't help myself we said it at almost the same time
Old Dec 15, 2003 | 07:49 PM
RPJ's Avatar
RPJ
hey, thanx for the suggestion. the problem with this is that i have no idea were the kill switch is i just got hte bike and never got instructions on it. please let me know. also i jsut rolled it down a hill and got it to crank but when i turned it off it didn't start back up. when i hit htestart button not a thoing makes a noise or anything.
Old Dec 15, 2003 | 08:20 PM
EXRydaH's Avatar
its a red button under the lights its right there cant miss it
Old Dec 15, 2003 | 09:44 PM
RPJ's Avatar
RPJ
thanx, i didn't realize that was the dead man. thats not it. we jsut rolled it off again and now the starter always works. the new problem is the accelerator. it keeps reving high without me touching the accelerator. no one can fix it here. any suggestions?
Old Dec 15, 2003 | 09:49 PM
95wolv's Avatar
Sounds like you either have a sticky throttle cable, or an air leak in the intake. to find an air leak, spray carb cleaner around the intake while it is idling, if you hit a spot that causes it to rev, that is your leak. otherwise, pull the cable and see if it moves smoothly, if not, try spraying some lube in to free it up.
Old Dec 15, 2003 | 10:06 PM
snowbuster's Avatar
or u might have the choke on?
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
Hondaislife
May 28, 2015 01:43 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
