440ex?
Old Dec 22, 2003 | 05:59 PM
WhiteBros440EX's Avatar
Default 440ex?
will a 440ex kit with a stage I cam make me lose my bottom end? i think this may be a dumb question but im asking it
Old Dec 22, 2003 | 06:36 PM
cals400ex's Avatar
Default 440ex?
you will have plenty of bottom end power with the stage 1 cam. it will seem more usable too. i would suggest getting ross or je pistons since the wiseco pistons have incorrectly labeled compression ratings for the trx400ex. if you don't want to run race gas, i wouldn't run over 10.8:1 with the ross or je pistons. good luck
Old Dec 22, 2003 | 08:03 PM
Default 440ex?
if i got a je or ross piston where could i get them? do they come as a kit with a sleeve and piston and everything all together? im all confused lol would you mind telling me the things i need to know like what does it come with and what set up i should use? i would really appreciate it
Old Dec 22, 2003 | 10:29 PM
Trx440's Avatar
Default 440ex?
CT sells Ross pistons. I had an 89mm 11.5:1 in my 440 from winter of 98 to summer of 03. Never had to do a topend, only valve adjustments. It liked 100 octane but would run on pump premium in a pinch.
Old Dec 23, 2003 | 01:08 AM
cals400ex's Avatar
Default 440ex?
give C&D racing a call. they will be able to answer all of your questions. the # is 308-696-7805.
you will have to tell them "cals400ex" sent you. dusty at that shop knows me as "cal." that should be enough to get a decent price. if not, pm me and i will tell you what you need to do. the sleeve will need to be pressed into your cylinder. a local shop will have to do that for you, unless you send your cylinder in somewhere. C&D will be able to send you everything you need besides the fact that you need the sleeve pressed in. they can probally do that for you if you send in the cylinder. just give them a call.
Blodg500RX
May 6, 2001 06:42 PM
mx400exer
Mar 14, 2001 05:08 PM
mhiggins36
Mar 1, 2001 02:00 PM
Robby440ex
Jan 30, 2001 05:09 PM
Robby440ex
Jan 29, 2001 11:16 PM
