SERVICE MANUAL
Old Dec 26, 2003 | 11:46 PM
4rider's Avatar
Default SERVICE MANUAL
does anyone know of a site with the sevice manual for a honda foreman 400 4x4 (trx400fw). not one that i can buy but one that is just there for anyone to look at and find measurments in.
Old Dec 27, 2003 | 02:10 PM
4rider's Avatar
no help ?
Old Dec 27, 2003 | 04:27 PM
hondabuster's Avatar
Depending on what year it is...you could try the local library, they have the climer and haynes manuals .
Old Dec 27, 2003 | 11:52 PM
sparky259's Avatar
i got a repair manual for my rubicon and i has excellent info in it. REPAIR MANUALS.COM good luck
Old Dec 28, 2003 | 12:15 AM
Coyotechaser's Avatar
What measurements are you looking for?
Old Dec 28, 2003 | 11:12 AM
fast440's Avatar
ebay almost always has manuals. It's where I get all of mine for cheap
Old Dec 28, 2003 | 12:27 PM
4rider's Avatar
im looking for the measurements of how much the tie rod should be out. Its a 98 foreman
Old Dec 28, 2003 | 01:27 PM
Under the specifications it has the tie-rod ball-joint spacing at 349.5 mm or 13.76 inches. (400 model)
Measure the distance from each locknut to the end of the threads and compare it with the above. If it it's incorrect, loosen the locknut and reposition the locknut and ball-joint on the threads. Position the ball-joint at each end of the tie-rod so the studs face 180-degrees away from each other.
Torque specs- Tie-rod stud nuts and tie-rod locknuts- 40 ft-lbs.
Old Dec 28, 2003 | 07:55 PM
4rider's Avatar
thanks alot man
Customer Service #1
May 15, 2020 08:46 AM
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
