Drilling out bolt on a 2001 rancher
Old Jan 31, 2004 | 06:11 PM
Blazer19's Avatar
Default Drilling out bolt on a 2001 rancher
Well i found out that the bolts on the right side of engine as your sitting on it are supost to be the same lenght. They are item # 17 if you look at a diagram of the cyclinder head. They go from the top of the head down to the crank case. My question is as follows: is the bolt holes in the crankcase blind or do they go all the way though. I want to drill out the broken bolt but dont want to tear the engine down to do it. If its blind then i can drill it out and vaccum out the metal particles. if they go though then i will have to pull engine apart and i dont know how hard that is to do?
Old Feb 1, 2004 | 12:29 PM
Blazer19's Avatar
Anyone?
Old Feb 1, 2004 | 01:04 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Have you considered using a reverse drill type bolt remover? Not sure if this will help in your case but it's a backwards thread drill bit that is hardened and made to remove broken bolts and stripped head screws. You can get them at Sears. If it works it would be less hassle that trying to drill and tap.
Jaybee
Old Feb 1, 2004 | 01:26 PM
Blazer19's Avatar
Thanks for your reply. i dont want to start drilling untill i know if the hole is open to the engine crank case. I dont want to drill though and metal go into engine.
Old Feb 1, 2004 | 01:40 PM
racerjohnbf's Avatar
As long as the bolt isn't frozen or really tight in the hole the backwards drill bit should work. You won't drill all the way through the bolt, as soon as the backwards drill bit bites into the bolt it should spin right out. If not you pobably will have to drill and re-tap the hole. How did the bolt break off? If it broke off by over tightening it then the reverse drill will probably work, but if it broke while trying to loosen it, it brobably won't. I hope this helps.
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
35dodge
Sep 29, 2015 09:40 AM
Clint Russell
Sep 25, 2015 03:20 PM
