Same size fronts and rears?
Old Feb 4, 2004 | 06:43 AM
DaRiot's Avatar
Default Same size fronts and rears?
I am looking to replace the stock tires and am wondering if I could go to the same size front to back?
Something like a 26-10-12 or 26-12-12.
This would allow me to rotate the quick wearing backs to the front.
Any thoughts?
Old Feb 4, 2004 | 09:00 AM
YAMAGRIZ's Avatar
26-10-12's will work all around, one question, are the rims the same offset front and rear? If not you'll have to dismount the tires to rotate them, (a real pain with larger 6 ply tires). Another thought, might be better to run the wider rears and just replace them when they wear out. Mine seem to wear about twice as fast as the fronts so when the second pair of rears were shot I replaced all 4.
Old Feb 4, 2004 | 09:23 AM
SHOTGUN's Avatar
If I understand your question right,
yes, you need to run the same size tires front and back because when in 4 wheel drive every thing needs to turn the same speed.
Old Feb 4, 2004 | 09:31 AM
YAMAGRIZ's Avatar
Tire diameters need to be the same (on most 4x4's). Running different widths is fine (most machines come stock with different width tires front/back).
Old Feb 4, 2004 | 09:51 AM
nyroc's Avatar
You will need to make sure the rears are at a higher pressure than the fronts or the 4x4 shifting won't work as well. The fronts need to be slightly smaller that the rears (not a whole tire size). I'm not saying use a 26" in back and a 25" in front. Tire manufacturers typically make the tires commonly used on the back a little bigger to facilitate easier steering in 4x4 and easier shifting in and out of 4x4.
Tires do not roll as far as their diameter X PI(3.14159). Their rolling distance has to be measured, and it also depends on load and rolling surface. Although you probably don't have to do this, you would want to make sure the rear tires roll about 2 inches further than the front ones in 1 revolution in order to insure proper operation of you machine. You can mess with the air pressure until your 4x4 shifting is acceptiable.
If the tires roll the same, it makes steering hard in 4x4 and sometimes shifting into 4x4 becomes more difficult. If the tires roll 4 inches different, then it causes a mechanical impact when shifting into 4x4 and a lot of drag while driving in 4x4.
Old Feb 4, 2004 | 10:33 AM
SHOTGUN's Avatar
nyroc;
I'm glad to see you posting. Good information!
Old Feb 4, 2004 | 07:13 PM
DaRiot's Avatar
I knew the overall tire height has to be the same, I was curious about width.
Thanks for the help.
Welcome back Nyroc...... I did the muffler mod and I LOVE it! Thanks
Old Feb 4, 2004 | 10:32 PM
SHOTGUN's Avatar
Sure the width can be the same, you just need a different off set rim if the front tire is wider to allow for turning.
Old Feb 5, 2004 | 11:04 PM
SHOTGUN's Avatar
600 lbs of bad news...lol the old girl is getting a face lift.
Did you ever get a number for Adam?
Old Feb 6, 2004 | 12:08 AM
Football21's Avatar
I have seen first hand 27x12x12 all around. (looks like a little jeep). I am about to get new tires and want to know if 28x12x12 all around will fit. If anyone has heard of this or seen this please let me know. Thanks
WilliamBos
Jul 13, 2015 02:11 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
