TRX450R-Close Ratio Transmission
Old Feb 9, 2004 | 08:40 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default TRX450R-Close Ratio Transmission
Gear ratios, 1st -5th:
2.071
1.625
1.333
1.120
0.963
400EX for comparison:
2.917
1.938
1.474
1.182
1.000
Old Feb 9, 2004 | 09:18 PM
steadyfreddie's Avatar
No wonder it feels so tall. It is.
Old Feb 9, 2004 | 11:57 PM
Red Rider
Sprockets are 38/14, just like the 400EX.
Old Feb 10, 2004 | 12:38 AM
BG400's Avatar
So does that mean the 450r has more speed or more low end grunt??
Old Feb 10, 2004 | 12:44 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Probably both
Old Feb 10, 2004 | 01:00 AM
maddog56's Avatar
lower gear ratios mean higher top speeds. You will notice the 450 has a much lower 1st gear ratio, giving up some low end grunt. But 5th on the 450 is just a little lower than the ex, losing top end.
The point of the post, however, is the ratios and thier relation to each other. Notice that the difference in the gear ratios of the ex is larger between any 2 gears than in the 450. This means that the rider needs to shift faster throughout the powerband.
Old Feb 10, 2004 | 01:18 AM
CroBiker's Avatar
ok, i'm a lil confused. on the 450, because of the close ratio gearing, do u have to shift faster? or is it that with the 400 cuz of the lack of close ratio gearing, that you have to shift faster?
Old Feb 10, 2004 | 03:25 AM
Red Rider
On the 450, the steps between gears are smaller. So, you are going to run out of gear sooner, and therefore need to shift sooner. On the other hand, you don't want to short shift the 450, because the motor does its best work at higher RPM.
Old Feb 10, 2004 | 11:48 PM
CroBiker's Avatar
ok, kool. that reminds me of when i rode my buddie's yfz 450 after riding my 400EX. if i pulled a gear low while turning, it would stall, but i felt like i was shifting every half second when accelerating. i prefer the way the EX is set up. jmo
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
rockinkgin
Sep 25, 2015 01:52 PM
WilliamBos
Sep 22, 2015 04:07 PM
