Need help figuring out sprockets
Old Feb 16, 2004 | 02:14 PM
Sandrider503's Avatar
Default Need help figuring out sprockets
Hello I have a 03 400ex. I hear you guys talking a teeth on front and rear sprockets. I'am a little confused on the whole deal. I just had my FlyWheel lightend and I heard it takes away from some of your bottom end power. Is there a certain toothed sprocket that will help regain some bottom end torque and power.
Old Feb 16, 2004 | 02:27 PM
YouSuk678's Avatar
Basically your 400ex comes with a stock 15 tooth front and a 38 tooth rear. when you add a tooth to the front it DECREASES your accel and bottum end. However, if you take a tooth away it will INCREASE your bottum end. It is the exact opposite with the rear. If you take away from the rear it will DECREASE the accel and bottum end and if you add it will INCREASE bottum end. Here is a calculator for sprockets, http://home.earthlink.net/~gellett/400ex.htm If you are looking for more bottum end i would suggest takeing away a tooth in the front (because it will be the easyest to change) and see what you like. I hope i helped out some with the sprocket confusion.
Old Feb 16, 2004 | 05:57 PM
What is a good sprocket too run I here sidewinder are good I talked to the owner on the phone the other day. I'am not sure if he was blowing smoke or what but he says his sprockets are the best out there.
Old Feb 16, 2004 | 06:21 PM
fidge1's Avatar
sprocket specialties
Old Feb 17, 2004 | 10:21 AM
steadyfreddie's Avatar
Not being a jerk here - just clarifying. Their name is sprocket specialists, and they also get my vote for nice stuff that's inexpensive.
Old Feb 17, 2004 | 07:21 PM
I acctualy think I'am gonna wait and see how much bottom end power the lighting of the Flywheel causes.
buddieboy
Dec 9, 2016 05:50 PM
wrencher82
Sep 28, 2015 10:02 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
dakotah
Sep 26, 2015 04:25 PM
wrencher82
Sep 24, 2015 03:39 PM
