4x4 problem
Old Apr 3, 2004 | 02:13 PM
Rodmax's Avatar
Default 4x4 problem
Hi , I have a 4x4 problem...2004 sp 500 ho. I broke the right front yoke, got a new universal joint and yoke, installed it and still dont have any pull on that wheel!!! Talked to dealer and took it all apart again cleaned everything and found the armature plate bent a little... straightned it and reinstalled all parts... and same result ..machine only pulls on three wheels... any Ideas.
My dealer is not close enough to visit, have to ship the machine...Thanks Rodney..
Old Apr 3, 2004 | 02:39 PM
Polaris500HO4x4's Avatar
Default 4x4 problem
is the half shaft turning at all. if it is and the wheel isnt engaging then you may need at check out your hubs.
Old Apr 3, 2004 | 05:43 PM
Rodmax's Avatar
Default 4x4 problem
Yes the shaft is turning... trouble is in the Hub...but I dont know what it is..or how to fix it!!!
Old Apr 3, 2004 | 07:38 PM
Traildog's Avatar
Default 4x4 problem
If your armature plate was bent you will need to replace it. The tolerance is only 0.0015" so I see no way of straightening it.
Old Apr 3, 2004 | 07:48 PM
Rodmax's Avatar
Default 4x4 problem
Thanks, that is the info i needed... Now I'll order one on Monday and might have it by Thursday,#$%%%$%$# another week without riding, that will make 3 weeks.
Old Apr 4, 2004 | 01:56 AM
Traildog's Avatar
Default 4x4 problem
Three weeks only? I haven't ridden since NYD.
Old Apr 4, 2004 | 08:31 PM
Rodmax's Avatar
Default 4x4 problem
Can anyone tell me if i will cause more damage if i ride my quad with a damaged armature plate??(while I wait for the new one!!!)
Old Apr 5, 2004 | 01:37 AM
Traildog's Avatar
Default 4x4 problem
Probably not, it just means your 2WD won't work.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
