finally have time to get the bikes going... problem
Old May 6, 2004 | 05:28 PM
250rctracing310kit's Avatar
Default finally have time to get the bikes going... problem
hey all, i now have a little time to get my bikes going. i have an 82 250r and it dident start at first. i flushed the tank, changed the spark plug & oil. i took off the carb because its been sitting before i bought it. i put my 85's carb on it (38) and with some starting fluid and a bunch of kicks it started. but will not stay on. it only stays on for like a half a min. (just until the starting fluid is gone)...........im getting the carb that was on it rebuilt. i also took off the reed but cracked the seal. i took it off until i get a new one. could this be the problem, because its not sealed?
Old May 6, 2004 | 05:30 PM
drummerguy84's Avatar
it could be...does this gasket seal the carb to the engine?..I know any air escaping into the engine is bad...too much air kills the engine...
Old May 6, 2004 | 08:03 PM
HA2's Avatar
HA2
if there is a leak, it will run like crap or not at all.
Old May 6, 2004 | 08:13 PM
dragracer789's Avatar
Usually when you have an air leak it will start easy and then rev up with nothing stoping it. When it finally started how did it run? Does it have to compression? does it have good spark?
Old May 7, 2004 | 12:18 AM
HA2's Avatar
HA2
ive started my buddies R after forgetting to tighen the intake boot down to the cylinder. it was completely out of control when it started and reved really high and had almost no throttle response.
Old May 7, 2004 | 06:20 PM
86250Rs's Avatar
Nice R HA2. I have one ? what is that a pic of you have on your pics page that says whoops, dosent look like anything I've ever seen on an R before.
Old May 7, 2004 | 08:25 PM
HA2's Avatar
HA2
thats the swing arm/axle on my brothers old buggy. it many a beer were drank while replacing that thing along with the other side.
thanks for the compliments, but its got a lot of work to be done that i fear i wont be able to finish by October.
Old May 7, 2004 | 08:26 PM
HA2's Avatar
HA2
what axle are you running?
whitty
67
Feb 24, 2021 02:52 PM
Bassassasian101
Jun 10, 2015 06:23 AM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
blaze_master
May 26, 2015 11:18 AM
Codyv20
May 26, 2015 09:51 AM
