Anyone replace their steering bushing?
Old May 8, 2004 | 07:36 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default Anyone replace their steering bushing?
Went to replace the one on the Boss, and it is riveted in place. Just curious, did you bolt the new one, or did you re-rivet it. It's a pretty heavy duty rivet. Just worried about the clearance if I use bolts. Could only be a problem if I want to turn right. Of course if I can only turn left, it becomes a NASCAR limited edition.
Old May 8, 2004 | 07:51 PM
thewayout420's Avatar
the one hpd sells comes with nuts&bolts so im assuming it will be ok to use them..
Old May 8, 2004 | 08:29 PM
Supersock
Hired Gun!
I looked at the picture of the HPD. It looks like they have countersunk the bolts. I may just modify the stock piece to accept the same kind of bolt. If anyone else out there is going to change theirs, just get the HPD part. It's about 10 bucks more, but after all I am going to have to do now, it's worth it.
Old May 8, 2004 | 11:30 PM
BigBadScrambler's Avatar
I replaced mine with the HPD part. It uses counter sunk allen head bolts with locknuts. You have to drill and/or grind the rivits off and drill out the mounting hole to accept the new bolts
Old May 9, 2004 | 01:46 AM
GreenMeanie's Avatar
I used a hammer and chisel to remove to rivets on mine. Then I used a Dremel tool to open the holes up. I replaced mine with the HPD piece from RCR. Its a nice part and really tightened the steering up.
Old May 9, 2004 | 02:16 AM
EAB's Avatar
EAB
GreenMeanie... you joined in June 2003 and you just did your first post??? Not much of a talker eh?[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 9, 2004 | 04:49 AM
LOL[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] Welcome stranger[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 9, 2004 | 09:30 AM
ftwflh's Avatar
The HPD unit iswell worth the $$$$$.
Nondem
Feb 22, 2020 12:20 PM
Gtsordo
Jul 22, 2015 01:27 PM
mdrkcckv
Jul 22, 2015 09:10 AM
1966F100
Jul 12, 2015 03:01 AM
Scottma518
Jul 10, 2015 12:42 AM
