Broken throttle assembly
Old May 16, 2004 | 10:12 PM
Catalac's Avatar
Default Broken throttle assembly
I smoked a tree this weekend and broke the throttle housing where the cable goes in I was thinking about trying to get it alum welded. Has any one had any luck doing this or can you weld the cast alum? It still seems to work even though the cable is expossed??
If anyone has a used one let me know.
thnx
Old May 16, 2004 | 10:50 PM
Ball's Avatar
On what?
Old May 16, 2004 | 10:51 PM
kodiakbob's Avatar
I will assume, from your icon, that you have a Raptor.
I once did a chest plant in mine. Here's how to fix it.
I used a piece of 3/8" steel fuel line as a sleeve, by cutting threads on the outside of it with a 10mm die, then cutting it to about 3/8" in length. You will have to remove the throttle cable from the housing. Then, with the two old throttle housing pieces held together, screw the new sleeve into it until it is counter sunk enough to screw the throttle adjustment back into it.
Or, you could spend a hundred bucks on a new one from yamaha.
Old May 16, 2004 | 10:54 PM
Yamaha660R's Avatar
If you can't get your throttle assembly fixed, you can buy a complete assembly through Alba's Factory Replacement Parts finder for $105. That is the entire throttle assembly.
Old May 16, 2004 | 10:55 PM
Ball's Avatar
Or even better, you can probably pick one up for a third of that on Ebay.
Old May 17, 2004 | 12:00 AM
Catalac's Avatar
Yup on a raptor...
KB thanks for the fix, I will try to get a new one but also try your fix for a spare.
Norm
greg74
Sep 10, 2019 03:03 PM
DFWSRT8
Aug 20, 2015 09:24 AM
Ashley S
Aug 6, 2015 12:56 PM
dougn85
Aug 5, 2015 07:20 AM
DeFox500
Jul 26, 2015 06:32 PM
