Does anyone know how to tighten the chain on a 325 Trail Boss???
Old May 31, 2004 | 01:23 PM
Skeeve's Avatar
Default Does anyone know how to tighten the chain on a 325 Trail Boss???
I just got done riding with my friends this weekend and it was terrible. Somehow during all that riding my chain became real loose and no one knew how to fix it, so I pretty much had to ignore it. But eventually the chain started falling off. PLEASE HELP ME! I have no clue what im doing!
Old Jun 1, 2004 | 01:14 AM
Blaney's Avatar
Hi,
loosen the two bolts on the bottom of the axle, under the hitch, and loosen the two bolts on the brake caliper, then you need a punch or a small screw driver to insert in a hole on the sprocket, (right hand side) roll quad forward until punch goes into the rear axle housing. (near top of housing) Now by moving quad forward or backward you can loosen or tighten your chain. seems awkward the first time, but pretty easy after that. If you have owners manual it is in there as well. Hope this helps you out.
Old Jun 1, 2004 | 01:50 AM
scramblerXrated's Avatar
if its a newer model, there will also be a place near the center of the axle that you will be able to rotate the axle with a large crescent wrench.
just like BLANEY said, youll need to loosen the axle bolts AND the caliper bolts before the axle will turn. rotate the axle until theres about 1/2 inch play in the chain. (manual says 3/8 inch,, but i like the chain just a tad looser just incase.
if its an older model,,, you might need to compress the suspension while you do all of this ... get a BIG buddy to sit on it for you.
X
Old Jun 1, 2004 | 08:34 AM
scootergptx's Avatar
Supersock
Hired Gun!
If you have a big (really big) set of channel locks or wrench, you can also roll the axel when you have it loosened. On my 2000 you don't have to use a punch, just roll it forward or backward to tighten or loosen.
Old Jun 2, 2004 | 01:34 AM
King244's Avatar
hey blaney, how is your trailboss....im thinking of getting one for my girl...does it have enough speed?
Old Jun 2, 2004 | 02:21 AM
Blaney's Avatar
my wife loves her trailboss, we put a rcr stage 1 kit on it and with her 95 lbs, it wheelies all day long for her. But her passion is the mud...the trailboss goes through things i really didnt think she had a chance in he!! of getting through....pull all your regular maintenance and it should be a great quad for your girl. they are very comfortable to ride and stable to make her feel confident. Good luck and any other questions, just ask!
Old Jun 2, 2004 | 09:44 AM
King244's Avatar
beautiful!
Thanks for the info....much appreciated...
Hondapolaris8596
Jul 28, 2016 03:17 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
95wolv
Jul 17, 2015 08:13 PM
