epi clutch kit
Old Aug 3, 2000 | 04:42 PM
trailbreaker's Avatar
how hard is a clutch kit to install?i changed secondary springs allready but never messed with the clutch.i just wanna know what im getting into
beforehand..thanks
Old Aug 3, 2000 | 08:34 PM
CaptNemo's Avatar
If you changed the secondary clutch spring already, you've done the hardest part. The primary spring and weights just bolt in.
Remove the aluminum cover from the primary clutch, and the primary spring is staring right at you. Unbolt the weights and press in slightly on the outer sheave and the weights will come out.
Old Aug 3, 2000 | 09:27 PM
thanks alot....thats what i needed to know
Old Aug 4, 2000 | 12:48 AM
JWC's Avatar
JWC
Just make sure the "X" on the cover w/ the 6 bolts and the center bolt line up with the rest of the "X" on the rest of the clutch. Its balanced that way.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
