SLIPPIN BELT NEED HELP
Old Aug 8, 2000 | 12:17 AM
will's Avatar
We have a 95 400 Explorer and when I go into water just above halfway on the rim sometimes the belt will slip. I am thinking about putting silicone around the seal and maybe snorkels???
Also when I get into a hard climb it smells like I am burnin the belt I am in low range. Do I need to replace the buttons?
Any help will be appreciated
Old Aug 8, 2000 | 01:07 AM
CHICKENman's Avatar
HOw long since belt has been replaced?CM
Old Aug 8, 2000 | 09:42 AM
BaDD500's Avatar
To keep water out of the belt drive, keep the throttle going. Don't stop or you will suck in water. As for the belt smelling like it's buring up, if the problem started happing now and the machine is a 1995 modle, you may need to replace the belt.
BaDD500
1998 Sportsman 500 EBS
2000 Magnum 500 EBS
2000 Traxter XT 500
2000 Chevrolet Tahoe LS 4x4
Old Aug 8, 2000 | 11:17 AM
Thor's Avatar
Will,
I think you are right about the buttons. Something is worn out in the clutch assembly. A slipping belt on a 2 stroke 400 in low range is a rare condition.
Old Aug 8, 2000 | 11:23 AM
Lurch77's Avatar
I agree with the above comments. You probably need to replace the belt. Usually once you slip it real good, you will need to rplace it, or it will slip easier.
As for water causing it to slip when it is only at wheel deep, sounds like the seal around the clutch case is bad. I would start there on that one.
Old Aug 9, 2000 | 12:41 AM
will's Avatar
Thanks I believe I will try the seal and maybe new buttons will pick them up tomm. since my piece is going to the shop. I keep the throttle down in the water and I have made the belt slip quite a few time the belt is five years old maybe it is time for a new one
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
