Starter Block Off On A 400?
Old Jul 1, 2004 | 02:05 PM
Scrammy400's Avatar
Default Starter Block Off On A 400?
I know various places (HPD, HSP, RCR) all sell these billet plates. But they are not very clear on their description. Will it remove the starter, wiring and battery which means that I will have to pull start from now on? How much weight will I save. Really the battery is not needed as I run no head lights and it would be nice to get rid of the steel box and all the wiring.
Thanx Adam
Old Jul 1, 2004 | 02:29 PM
tbsleeper's Avatar
the plate gos where the starter enters the flywheel. so it removes teh starter and battery and all wiring that u want.
Old Jul 1, 2004 | 09:18 PM
modquad's Avatar
You can easily install the White Bros battery elim. capacitor, and still have lighting capabilities. Also, if you're removing the starter, you might as well have your flywheel race lightened. You will notice the difference. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 1, 2004 | 10:12 PM
Troyer23J's Avatar
What kind of wiring does the battery eliminator involve?
Old Jul 1, 2004 | 10:38 PM
Scrammy400's Avatar
That means that I would be limited to pull start and have no back up right. Also to get rid of the battery and box you would gave to cut off the steel box on frame and file smooth and paint. Has anyone else done this?
Old Jul 1, 2004 | 11:09 PM
Whitedog's Avatar
YEP, I did. and I made my own starter block off plate. Just lay the starter down on a pice of aluminum- trace an outline with holes. And cut with a jigsaw. Then permatex it. Save your money my friend. Ud be suprised what you can make out of a alum. road sighn.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 3, 2004 | 11:42 PM
Scrammy400's Avatar
I've recently looked at a friends that he hot from HPD, very simple to fab but still undecided as I ride in alot of mud and water and its always nice to have a back up. (ive siliconed my pull handel for the sake of getting no water in the rewind, hopefully never have to use it unless my starter packs out). Ill sleep on it and soon make a decision.
Old Jul 4, 2004 | 01:03 AM
modquad's Avatar
Installing the starter block off, and having your flywheel milled will have no effect on your reverse. Selecting reverse is a fully mechanical event which you initiate via the shifter. [img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
