Wolverine Clutch
Old Jul 24, 2004 | 12:34 AM
jd4115's Avatar
Default Wolverine Clutch
Ok guys,
I hear you can drill the clutch. Let me see if I understand the concept. If you lighten the clutch by putting holes in it, it will take a higher RPM to engage. This higher RPM is where the 350 Wolverine has more power, in the top end. This being the case, will it act like I put lower gears in it? Reving higher but going slower. Will this help if I put bigger tires on it? If this is wrong, could someone please explain it to me.
Thanks
jd4115
Old Jul 26, 2004 | 09:35 PM
SpDdEmOn's Avatar
It will just change the engaugement rpm on the clutches. Once the clutch is engauged it has no other effect. You will still have the same gearing and power.
SpDdEmOn's Avatar
Put a manual clutch on it and engauge it wherever you want it.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
