atc 70 clutch
Old Jul 25, 2004 | 06:44 PM
tangerine's Avatar
Default atc 70 clutch
I had trouble with my shift fork on atc 70,when i pulled the case i decided to pull clutch and clean and put back in.Now when i start it in neutral and put it in gear it jumps and dies,the clutch does not slip at all.What im looking for is an exploded view of assembly dissasembly procedure Im sure the clutch is ok but maybe missed a step or something on reassembly.thanks ron
Old Jul 26, 2004 | 02:41 AM
ThrashAndCrash's Avatar
I don't know what year but here is one from a 81.....HERE
Old Jul 26, 2004 | 08:27 PM
tangerine's Avatar
thanks alot thats pretty much what i needed .....
Old Jul 15, 2005 | 02:18 PM
waynerod's Avatar
My boys' ATC70 is slipping in gear - and sometimes jumps out of gear.
It is getting worse.
Is it that big of a job to crack the sucker open and check for the problem?
What do you think the problem may be?
Shift forks perhaps?
Special tools required (I know I need a special puller for the alternator)?
I've rebuilt a few car motors (chevys mostly) - this motorcycle thign is a bit new.
I did learn that adjusting the point on the little guy makes a whole heck of a lot of difference!
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
