Warrior jetting problem
Old Jul 27, 2004 | 12:03 AM
spider15068's Avatar
Default Warrior jetting problem
i have a dmc pipe what is a good jet i try a 155 main jet and a stock small jet .
should i chang the small jet to a 45 ? how about the niddle?
how do you take out the swing arm bearing in the carrier?[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 27, 2004 | 01:17 AM
DS650BajaRunner's Avatar
Try a 150 main jet and for the pilot jet try the 45 to see if it idles ok. if you want to replace the swingarm bearings and they are sealed get ready for some headaches i have tried and tried and tried until finally i got it out use an impact gun and lots and lots of 40-WD it will help i screwed up the pivot shaft( the bolt that is holding the swingarm) and had to buy a new one i hammered it down until it came out but i do not recommend that if you dont want to buy a new bolt.
If you have a puller to pull it out that would be best.
Oh and btw welcome to the forums.[img]i/expressions/face-icon-small-wink.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
Captjay
Jul 23, 2015 12:33 PM
Reactant
Jul 16, 2015 10:29 PM
cSchwartz
Jul 9, 2015 02:43 PM
